SYNC4 Splash Screen not changing
Maurix
Vehicle: Ford Focus ST-LIne 2022
Post by Maurix »
Hello
i Trend to change the Splash Screen on my FOCUS ST Line 2022 to different styles but I always get the FORD Bootup screen, seems the blocked this on newer Focus or there are specific other settings to do .
Was anybody able to perform this on a Focus from 2022 or later ?
Thx Maurix
Maurix
Re: SYNC4 Splash Screen not changing
Post by Maurix »
no replies here but got it working now :D
codix
Vehicle: Ford transit custom my2024
Post by codix »
Can you explain how you have changed the spash screen? I've tryed this mod on my transit custom 2024 (sync4) without success.. :|
Maurix
Post by Maurix »
I used this info , after setting the Apim to Focus and the other to ST Performance my Focus 2022 came first up with the normal FORD Bootscreen.
1h later I went into the car and the ST Performance Boot Sequence came up and it´s working
Kindly Maurix
you need to try out the different option in the list where the different splashscreens are listed
some works with the new SYNC 4 some not
In the APIM module change the splash screen to Focus.
Under Vehicle, change it from Focus to none. This 100% works as this is what's over writing the splash selection.
This gave me the Ford Performance screen on the sync 4.
codix
Post by codix »
Thank you so much!
Iwill try your settings!
