2010 5.4L F150 engine into 2010 4.6L F150 body
wr9882
Vehicle: fORD F150, 5.4L XLT, 2010
Post by wr9882 »
i have decent 2010 3v 4.6L F150 body. i bought a totaled 2010 3v 5.4L F150 with 18,000 original miles for $500, i swapped everything, Engine, ECM, engine harness, transmission, T-case, instrument cluster, steering column, door actuators, exhaust, interior, except dash, rear end, drive line i even swapped the bumpers, i thought with, cluster, ECM, transmission, engine, steering column with key & fob , and engine with harness. i wouldnt have a patts problem, but here we are with the red little pad lock on my dash & the scanner saying time lock out. can anyone help me please. im all set to plug in but i only have 1 key & i only want to do it 1 time, i have a lot of work into this truck any help would be appreceated thank you
DAN1000
Vehicle: Maverick 2.0 2025
Re: 2010 5.4L F150 engine into 2010 4.6L F150 body
Post by DAN1000 »
You also need the BCM
