ISSUE w/version 2.3.69 BCMB
texasjohn6
Vehicle: F250 gasoline 6.2l 2019
Post by texasjohn6 »
I downloaded the new version 2.3.69 today and purchased the extended license. My older version would not allow me to configure change.
My issue now is when trying to play/read the BCMB, it only displays High Beam - DTC, Low Beam - DTC and Turn Signal - DTC.
I need to verify my correct tire size and ger ratio. I have tried searching 'tire' and 'gear' but nothing displays.
I originally change the tie size in 2023, no issue since. Until 5 days ago I had the check engine light come on. I found codes:
P0451 - the Evaporative Emission System (EVAP) Pressure Sensor has a Range/Performance issue
P160A - The P160A fault code, often seen in Ford vehicles, usually signals a Control Module Vehicle Options Reconfiguration Error, most commonly triggered after changing tire sizes and requiring reprogramming or module relearns (PCM, TCM, AWD) using tools like FORScan. It can also indicate deeper issues like communication faults or internal hardware failures if it persists after calibration.
Common Causes:
Tire Size Change: The most frequent cause, where the Body Control Module (BCM) update doesn't sync with other modules (PCM, TCM, AWD).
I cleared the P0451, but can't verify the P160A or the previous change.
2019 Ford F250 6.2l 4X4
The change was from the 245/75R17 (32")to 275/65R20 (34"), both are original equipment sizes.
Why can't I see ALL of the BCMB information ?
