LED LIGHTS FORD SMAX
amoss12001
- Vehicle: Ford focus tdci kkda 1.8 2006
hi I'm having a problem with the errors warning on dash about low beam fault after fitting the led bulbs i cant find a way of disabling this has any one had this problem and found a way to do this any help would be gratefully received and appreciated ford smax 2014
Velcrohead
- Vehicle: Ford Transit Custom 290 LTD E-Tech 2.2 2014
Re: LED LIGHTS FORD SMAX
I have a Transit Custom, I had the same problem and went into the BCM and disabled Headlight Monitoring, no more errors.
amoss12001
The problem on this is that is not showing on the smax
Velcrohead
Have you tried looking in engineering mode?.
amoss12001
Been it engineers mode and also all Hidden unless I'm not doing it right it's just not in the version I'm using tried looking for outage as well it just doesn't come up at all and nothing on headlight monitor neither
You have to go in to [ IPC configuration ], and than write in the search box "bulb" and you will see an option where it says "bulb fault" disable that.
amoss12001
is there a way you could give me a idot guide on doing this as im new to doing this side if its too much then thats fine i will try and find videos on how to do this but i am great full for all the replys and thank ever one for all imput
amoss12001 wrote: Fri Jan 30, 2026 1:08 pm is there a way you could give me a idot guide on doing this as im new to doing this side if its too much then thats fine i will try and find videos on how to do this but i am great full for all the replys and thank ever one for all imput
