LED LIGHTS FORD SMAX
Posted: Thu Jan 29, 2026 2:12 pm
by amoss12001
hi I'm having a problem with the errors warning on dash about low beam fault after fitting the led bulbs i cant find a way of disabling this has any one had this problem and found a way to do this any help would be gratefully received and appreciated ford smax 2014
Re: LED LIGHTS FORD SMAX
Posted: Thu Jan 29, 2026 4:27 pm
by Velcrohead
I have a Transit Custom, I had the same problem and went into the BCM and disabled Headlight Monitoring, no more errors.
Posted: Thu Jan 29, 2026 5:14 pm
by amoss12001
The problem on this is that is not showing on the smax
Posted: Thu Jan 29, 2026 5:44 pm
by Velcrohead
Have you tried looking in engineering mode?.
Posted: Thu Jan 29, 2026 6:38 pm
by amoss12001
Been it engineers mode and also all Hidden unless I'm not doing it right it's just not in the version I'm using tried looking for outage as well it just doesn't come up at all and nothing on headlight monitor neither
Posted: Fri Jan 30, 2026 6:28 am
by cip
You have to go in to [ IPC configuration ], and than write in the search box "bulb" and you will see an option where it says "bulb fault" disable that.
Posted: Fri Jan 30, 2026 1:08 pm
by amoss12001
is there a way you could give me a idot guide on doing this as im new to doing this side if its too much then thats fine i will try and find videos on how to do this but i am great full for all the replys and thank ever one for all imput
Posted: Sat Jan 31, 2026 5:03 pm
by cip
amoss12001 wrote: Fri Jan 30, 2026 1:08 pm is there a way you could give me a idot guide on doing this as im new to doing this side if its too much then thats fine i will try and find videos on how to do this but i am great full for all the replys and thank ever one for all imput
