2014 ford fusion 2.5 se U0415
marv2525
Vehicle: 2014 ford fusion 2.5L se
Post by marv2525 »
hello i have a 2014 ford fusion i have a hard code of U0415 00 0A ( invalid data from ABS module). i know all 4 WSS work, there is no DTC light on, traction control is on, and steering wheel moves easy ( its not hard to move ). i noticed that the steering wheel angle doesn't move stays on 0* the brake switch works. i was listing to a podcast that talked about the same issue and they updated the ABS module and they say that fixed the problem. my question is has anyone ran into this problem any solutions or ideas? i really appreciate any information on this subject and help if you can, thank you in advance. just love the car and want to keep everything going good and stay on top of everything tks again.i have pics but wont let me post them
boosted_diesel
Re: 2014 ford fusion 2.5 se U0415
Post by boosted_diesel »
Steering angle sensor must work for abs and trac
marv2525
Post by marv2525 »
I think your right, I got 2 pids one moves value and the other one stays at 0, I think there might be something wrong with the sccm or the clock spring. Thinking its more the sccm though
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley »
Ford has limited our access to calibration files. If Forscan can't find it you will need Ford software like IDS to get it. Sometimes a forum user can get or find files so that's your only hope for doing this without paying Ford.
marv2525
Post by marv2525 »
Ya I had to use my launch 909e to do sas cal. And it still don't work. I figured that I need a new sccm, I looked all over the internet and it was saying that the data isn't trusted that's why it don't work but it came down to one pid had values and the other didnt so idk I just figured it was the sccm.
