How to put bcm back to factory
Anthonymark1986
- Vehicle: Ford transit mk8 2.2 diesel
Hello yes im pretty new to forscan and i ended up changing something and forgot what it was i now have a dtc code something about incompatible, i went onto bcm and clicked on restore all the way down but code still comes up, so maybe i need to factory reset the bcm, i have found the codes online just not sure how easy that will be
Re: How to put bcm back to factory
Download your as-build file from https://www.motorcraftservice.com/AsBuilt. When in Forscan, use this file to restore all the Factory BCM settings. Click the load all button and it should open a file explorer window where you can navigate to the saved file location and load it. You may need to move this file into the FORScan folder located on your computer, usually under "Documents". This is the location FORScan uses to reference files to load. The software will automatically load the required files for the module you are in, whether it be BCM, IPC, TCU and so on. In future, always click the backup all or save all button and create a backup of the module you are in before making changes. This will allow you to simply navigate to the stored file and load them. Both ways work, one is faster. My listed order of operations and/or locations may be a bit out as I am not connected to a vehicle navigating the system while typing this lol. Hopefully its close enough to get you through, its been a minute since I needed to do this. Key note: Don't change the file name, its your VIN# for a reason. Software references it to the vehicle you are connected to, these need to match or it won't load.
Anthonymark1986
Thats very hepful thank you so much
