2008 ford edge re programming PCM
Hi there, I am using version 2.4 .22 and whilst everything seems to be ok I keep getting the error "Downloading KNBE0TB: File not found" i have tried a number of times, wifi is good and i can run all other tests, every time i hit download for that particular file it says the same, other files have downloaded fine and are in the documents folder unzipped, any help would be appreciated, thanks Dave
