how do i understand my DTC report
the goat
Vehicle: c-max 1600 125hp 2011
Post by the goat »
hi all
new to all of this and new to the car Ford C-Max 2011 1.6 125hp petrol
I've a probelm with the car's info screen i can't get off it,
so I did a DTC test with forscan the report is attached can anyone give me a clue on what I'm reading in the report
years ago i would hve been able to work though it all,but age has turn my brain to mush and things are so hard to workout now
===OBD2_PCM DTC P0420-P===
Code: P0420 - Catalyst System Efficiency Below Threshold (Bank 1).
Note: The Powertrain Control Module(PCM) tests the catalyst efficiency by monitoring the rear Heated Oxygen Sensor. The Diagnostic Trouble Code(DTC) is set when the catalyst efficiency is below an acceptable level.
Status (-50):
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II (PCM)
===END OBD2_PCM DTC P0420-P===
===PCM DTC P0420:09-64===
Code: P0420 - Catalyst System Efficiency Below Threshold Bank 1
Additional Fault Symptom (:09):
- Component Failures
Status (-64):
- DTC Maturing - Intermittent at Time of Request
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 406749263 s ((null)) - Event time
-TOTAL_DISTANCE: 16485 km - Total Distance
-MODULE_VOLTAGE: 15.0 V - Control Module Voltage
-INCAR_TEMPERATURE: 23 °C - In car temperature
-OUTDOOR_TEMPERATURE: 23 °C - Outside temperature
-PWR_MODE_KEY: Running - Power Mode Key State
-FUELSYS: Closed Loop - Fuel System Status (Open/Closed Loop)
-LOAD: 47.45 % - Calculated Load Value
-ECT: 84 °C - Engine coolant temperature
-SHRTFT1: 3.13 % - Short term fuel trim 1
-LONGFT1: -3.13 % - Long term fuel trim 1
-SHRTFT2: -3.91 % - Short term fuel trim 2
-LONGFT2: -5.47 % - Long term fuel trim 2
-RPM: 2376 1/min - Engine Revolutions Per Minute
-VSS: 63.0 km/h - Vehicle Speed
-SPARKADV: 31.00 ° - Spark Advance
-IAT: 8 °C - Intake Air Temperature
-MAF: 15.76 g/s - Mass Air Flow
-TP: 21.57 % - Throttle Position
-FLI: 14.12 % - Fuel Level
-APP_D: 30.59 % - Accelerator Pedal Position D
-APP_E: 30.98 % - Accelerator Pedal Position E
===END PCM DTC P0420:09-64===
===PCM DTC P0430:09-64===
Code: P0430 - Catalyst System Efficiency Below Threshold Bank 2
Status (-64):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 46045673 s (Sat Jan 30 19:05:34 2027) - Event time
-TOTAL_DISTANCE: 16486 km - Total Distance
-LOAD: 45.49 % - Calculated Load Value
-SHRTFT1: 7.03 % - Short term fuel trim 1
-LONGFT1: -2.34 % - Long term fuel trim 1
-SHRTFT2: 2.34 % - Short term fuel trim 2
-LONGFT2: -4.69 % - Long term fuel trim 2
-RPM: 2453 1/min - Engine Revolutions Per Minute
-VSS: 64.0 km/h - Vehicle Speed
-TP: 21.96 % - Throttle Position
===END PCM DTC P0430:09-64===
===PCM DTC U0418:00-2E===
Code: U0418 - Invalid Data Received from Brake System Control Module 'A'
Status (-2E):
===END PCM DTC U0418:00-2E===
===SASM DTC None===
Successful DTC reading, no error codes found
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC U3003:17-68===
Code: U3003 - Battery Voltage
Additional Fault Symptom (:17):
- Circuit Voltage Above Threshold
Status (-68):
- Test not complete
Module: Antilock braking system
Freeze Frame #1:
-EVENT_TIME: 45107353 s (Thu Feb 05 11:39:13 2026) - Event time
-TOTAL_DISTANCE: 127745 km - Total Distance
===END ABS DTC U3003:17-68===
===ABS DTC C1A41:64-68===
Code: C1A41 - Clutch Pedal Sensor
Additional Fault Symptom (:64):
- Signal Plausibility Failure
Status (-68):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 45299612 s (Sat Feb 07 17:03:32 2026) - Event time
-TOTAL_DISTANCE: 127755 km - Total Distance
===END ABS DTC C1A41:64-68===
===RCM DTC None===
===END RCM DTC None===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===BCMii DTC B10D7:05-6C===
Code: B10D7 - PATS Key
Additional Fault Symptom (:05):
- System Programming Failures
Status (-6C):
- Test not complete
Module: Body Control Module
Freeze Frame #1:
-EVENT_TIME: 44074058 s (Sat Jan 24 12:37:37 2026) - Event time
-TOTAL_DISTANCE: 127693 km - Total Distance
-MODULE_VOLTAGE: 12.0 V - Control Module Voltage
===END BCMii DTC B10D7:05-6C===
===BCMii DTC B10D7:51-6C===
Additional Fault Symptom (:51):
- Not Programmed
Status (-6C):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 43141150 s (Tue Jan 13 17:29:09 2026) - Event time
-TOTAL_DISTANCE: 127518 km - Total Distance
-MODULE_VOLTAGE: 11.5 V - Control Module Voltage
-INCAR_TEMPERATURE: 86 °C - In car temperature
===END BCMii DTC B10D7:51-6C===
===BCMii DTC B112B:07-28===
Code: B112B - Steering Wheel Module
Additional Fault Symptom (:07):
- Mechanical Failures
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 45703617 s (Thu Feb 12 09:16:56 2026) - Event time
-MODULE_VOLTAGE: 12.5 V - Control Module Voltage
===END BCMii DTC B112B:07-28===
===BCMii DTC B11DB:83-2C===
Code: B11DB - Battery Monitoring Module 'A'
Additional Fault Symptom (:83):
- Value Of Signal Protection Calculation Incorrect
Status (-2C):
Freeze Frame #1:
-EVENT_TIME: 45966815 s (Sun Feb 15 10:23:34 2026) - Event time
-TOTAL_DISTANCE: 127773 km - Total Distance
===END BCMii DTC B11DB:83-2C===
===BCMii DTC B113D:12-6C===
Code: B113D - Sunroof Global Open/Close Control
Additional Fault Symptom (:12):
- Circuit Short To Battery
Status (-6C):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 44595169 s (Fri Jan 30 13:22:48 2026) - Event time
-TOTAL_DISTANCE: 127718 km - Total Distance
-INCAR_TEMPERATURE: 84 °C - In car temperature
===END BCMii DTC B113D:12-6C===
===BCMii DTC B1D06:09-6C===
Code: B1D06 - Left Turn Indicator
Status (-6C):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 44764502 s (Sun Feb 01 12:25:01 2026) - Event time
-TOTAL_DISTANCE: 127732 km - Total Distance
-MODULE_VOLTAGE: 12.3 V - Control Module Voltage
===END BCMii DTC B1D06:09-6C===
===BCMii DTC B1D07:09-6C===
Code: B1D07 - Right Turn Indicator
Status (-6C):
- Test not complete
Freeze Frame #1:
===END BCMii DTC B1D07:09-6C===
===BCMii DTC C111A:15-6C===
Code: C111A - Right Stop Lamp
Additional Fault Symptom (:15):
- Circuit Short To Battery Or Open
Status (-6C):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 44752330 s (Sun Feb 01 09:02:09 2026) - Event time
===END BCMii DTC C111A:15-6C===
===BCMii DTC B10EF:14-6C===
Code: B10EF - Sunroof Speed Output
Additional Fault Symptom (:14):
- Circuit Short To Ground Or Open
Status (-6C):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 43141207 s (Tue Jan 13 17:30:06 2026) - Event time
-INCAR_TEMPERATURE: 87 °C - In car temperature
===END BCMii DTC B10EF:14-6C===
===FCDIM DTC U2101:00-2F===
Code: U2101 - Control Module Configuration Incompatible
Status (-2F):
Module: Front Control/Display Interface Module
===END FCDIM DTC U2101:00-2F===
===RGTM DTC C2005:31-68===
Code: C2005 - Right Actuator
Additional Fault Symptom (:31):
- No Signal
Status (-68):
- Test not complete
Module: Rear Gate/Trunk Module
Freeze Frame #1:
-EVENT_TIME: 45619571 s (Wed Feb 11 09:56:11 2026) - Event time
-TOTAL_DISTANCE: 127761 km - Total Distance
===END RGTM DTC C2005:31-68===
===RGTM DTC B1161:15-28===
Code: B1161 - Left Rear Anti-Pinch Sensor
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 44236112 s (Mon Jan 26 09:38:32 2026) - Event time
-TOTAL_DISTANCE: 127705 km - Total Distance
===END RGTM DTC B1161:15-28===
===SRM DTC None===
Module: Speech Recognition Module
===END SRM DTC None===
===PDM DTC B12DC:54-2F===
Code: B12DC - Front Window Motion/Position Sensor
Additional Fault Symptom (:54):
- Missing Calibration
Status (-2F):
Module: Passengers Door Control Unit
===END PDM DTC B12DC:54-2F===
===PDM DTC B12DD:54-2F===
Code: B12DD - Rear Window Motion/Position Sensor
Status (-2F):
Freeze Frame #1:
-DLA_SED_DD07_BY_1_PID: error - DL_SED_DD07_BY_1_PID
===END PDM DTC B12DD:54-2F===
===PDM DTC U2010:15-28===
Code: U2010 - Switch Illumination
Status (-28):
===END PDM DTC U2010:15-28===
===DDM DTC B12DC:54-2F===
Status (-2F):
Module: Drivers Door Module
===END DDM DTC B12DC:54-2F===
===DDM DTC B12DD:54-2F===
Status (-2F):
Freeze Frame #1:
===END DDM DTC B12DD:54-2F===
===DDM DTC B12C2:15-6C===
Code: B12C2 - Puddle Lamp
Status (-6C):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 45704332 s (Thu Feb 12 09:28:52 2026) - Event time
-DLA_SED_40EB_BY_1_PID: Active - DL_SED_40EB_BY_1_PID
===END DDM DTC B12C2:15-6C===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===RFA DTC B102B:00-6C===
Code: B102B - Passive Key
Status (-6C):
- Test not complete
Module: Remote Function Actuator
Freeze Frame #1:
-EVENT_TIME: 44154794 s - Event time
Freeze Frame #2:
-EVENT_TIME: 46136235 s - Event time
===END RFA DTC B102B:00-6C===
===ACM DTC U3006:16-28===
Code: U3006 - Control Module Input Power 'A' Circuit / Open
Additional Fault Symptom (:16):
- Circuit Voltage Below Threshold
Status (-28):
Module: Audio Control Module
Freeze Frame #1:
-EVENT_TIME: 45634133 s - Event time
-MODULE_VOLTAGE: 8.8 V - Control Module Voltage
===END ACM DTC U3006:16-28===
===ACM DTC B1A56:15-28===
Code: B1A56 - Antenna
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 44505585 s - Event time
-MODULE_VOLTAGE: 11.8 V - Control Module Voltage
===END ACM DTC B1A56:15-28===
===ACM DTC B1D55:11-28===
Code: B1D55 - Antenna #2
Additional Fault Symptom (:11):
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 45187705 s - Event time
===END ACM DTC B1D55:11-28===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
DAN1000
Vehicle: Maverick 2.0 2025
Re: how do i understand my DTC report
Post by DAN1000 »
Your best bet is to clear the codes & see what comes back
