Ford Explorer PCM Replacment - Key Programming - How To Fix
oldhawaiian
Vehicle: 2007 Ford Explorer Sport Trac 4.0L
Post by oldhawaiian »
I wanted to share the experience fixing my Sons 2007 Ford Explorer Sport Trac 4.0L.
It was Bad PCM that we had replaced by ARES Technologies (gave them the Vin and the exact PCM model number that was on the backside of the unit - need to take it out to see it).
It was also a bad second key that would not reprogram to new PCM and we needed to run the Module Initialization program (right under the FORscan Erase & Program Keys option). You need to have 2 keys programmed in PATS AND run the Module Initialization program to let the PCM and PATS Module work together properly. Only THEN will the vehicle crank.
It was dying when warm. It was running fine otherwise.
My OBD2 read had a long list of codes on the first reading. Many PCM related codes, CAN bus communication issues, Modules, PATS issues etc.
After clearing the codes it was PCM, CAN Bus Communication and Module codes mostly.
I immediately thought it was the PCM relay, battery negative was a little loose or possible made negative grounding or the PCM.
After asking around some advice was to check the CAN Bus for proper Voltage on the low and high wire on the OBD2 connector. Also check the OHM reading there. I looked that up and we did that. It was withing range. I would recommend doing that as well. There didnt seem to be an issue with that wiring.
We checked the Battery voltage and removed all the negative grounds that we could see to the vehicle frame. Sanding them down.
We even replaced the battery with my battery just to rule that out.
We swapped the PCM relay with a backup I had.
The Vehicle had two Keys that would start. When it died it would either start again and die quickly, show PATS flashing rapidly or occasionally crank and not start.
When it ran it ran well. It ran longer cold (up to 5 minutes). Seemed electrical because of that.
It was hard to tell where the PATS cluster was on this vehicle - all kinds of different information. I thought it was the Immobilizer Transponder Antenna around the Ignition Key that was the issue. I thought the control was in there. I ordered that but before it arrived we ran the vehicle and pulled the wires and it still ran so we learned that PATS only works for 1 second and after that it wont kill and engine.
Then I think we pulled the Radio fuse and tested and ABS module fuse. Trying to rule out modules sending bad data to the PCM.
Then we focused on the Instrument Cluster (where the PATS module is) and where a Service Bulletin is concerning possible cracking in the solder joints when they stopped putting lead in. The cluster panel seemed fine though. Figured it might just be one or two connectors that were related to PCM?
We were going to pull that out and open it up to look but I decided to turn and AIR SPRAY CAN upside down and shoot the PCM to chill it. It worked - I was able to run routines with FORScan like PCM check that I could before unless cold. I tried to run and test again and it was bad (warmed up) and sprayed another can on it and it was good again.
THAT's IT! Ordered a new PCM through ARES Technologies for a really good price and good shipping (Hawaii).
Plugged it in but we weren't able to get TWO Keys to Erase and Program. Always just the one key. After 5 tries we figured the one key must be the issue. That key was made a local hardware store and they used a good key to read and paste the data to the other key making a CLONE (we think).
Ordered two new keys online and had a locksmith cut them at his shop. We were able to program two keys (we tried 3 but two were able to program at the time). I could see FORScan was showing 2 keys in the System.
Truck still would not crank over but PATS was NOT flashing on either key.
I ran the Module Initialization Program and then tried it and it Started right up and PROBLEM SOLVED!
FORscan Software save us from towing it to the Dealer and paying A LOT OF MONEY.
New PCM was $270 delivered. I paid the $20 for FORScan either with the Trial 2 months to support. The correct cable connector was $40. Used wifes laptop.
I hope I can help others with this information! 🤙
hueypilot
Vehicle: 2017 Ford Police 3.5L
Re: Ford Explorer PCM Replacment - Key Programming - How To Fix
Post by hueypilot »
Nice write-up. Thank you for taking the time.
