good evening, here is my configuration: Mustang GT 2018, Forscan 1 year licence and ODBLINK EX adaptator.
I don't have access to the all modules, for exemple not access BdyCM : what should I do?
No access BdyCM
- Vehicle: *** Ford ***
Re: No access BdyCM
See if this works:seb5091 wrote: Sun Feb 22, 2026 7:10 pm good evening, here is my configuration: Mustang GT 2018, Forscan 1 year licence and ODBLINK EX adaptator.
I don't have access to the all modules, for example not access BodyCM : what should I do?
Delete the FORScan Profile
FORScan often caches the vehicle configuration from the first time it was connected. If you added hardware, it won't show up.
Go to the Profile tab in FORScan.
Delete the stored profile for your 2018 Mustang.
Reconnect and select "No" when asked to use the cached profile to force a full, fresh read of the vehicle network.
MS-CAN (Medium Speed): Required for the Body Control Module (BCM), IPC, and HVAC.
HS-CAN (High Speed): Used for PCM, ABS, and Transmission modules.
Re: No access BdyCM
It works, thank you very much
Re: No access BdyCM
Thank you for getting back with the good news !!
