TPMS options not showing for 2018 Ford Explorer.
x84 Fox Body
Vehicle: F-150, Gas 5.0L, 2023
Post by x84 Fox Body »
Hello guys, im new here, I was trying to turn off the TPMS on my mom's 2018 Ford Explorer but dont see the options in the BCM or IPC? If anyone has any ideas or a data sheet to manually enter the numbers that would be great, thanks in advance.
Vehicle: *** Ford ***
Re: TPMS options not showing for 2018 Ford Explorer.
Post by f-wolf »
x84 Fox Body wrote: Tue Mar 10, 2026 12:56 am Hello guys, im new here, I was trying to turn off the TPMS on my mom's 2018 Ford Explorer but dont see the options in the BCM or IPC? If anyone has any ideas or a data sheet to manually enter the numbers that would be great, thanks in advance.
See if this will help you: https://www.youtube.com/watch?v=aZVFbyN8_-M&t=87s
x84 Fox Body
This is a great walkthrough video, however, when I look into the BCM and IPC I dont get any options for disabling or enabling the tpms sensors, ill see if I can get a screenshot of what im looking at.
Joh150413
Vehicle: Taurus,3.5 Ecoboost, 2016
Post by Joh150413 »
TPMS is a safety system. Ford will not give you the option to disable it. You may only disable it by modifying the as built data. Maybe someone has figured that out, I don't know.
