How change VIN in 2008 Ford F150?
luisdimas11
- Vehicle: F150, 4.2L, 2008
Hi, After replace the PCM in 2008 Ford F150 4.2L, my Launch Scanner and Forscan are reading a different VIN, I think it is the VIN of donor car. I tried to change it with forscan but it did not show me the PCM module at "Configuration and Programming" section. See the picture. How can I change it? Thank you
Re: How change VIN in 2008 Ford F150?
This will require a PCM Firmware update with Forscan version 2.4.22(2.3.XX will not even see the PCM VID block update configuration ), a One year license and an Adapter with FEPS capability such as the vLinker FS or a J2534 Passthru adapter with FEPS capability! See this topic: viewtopic.php?f=13&t=18751luisdimas11 wrote: Fri Mar 13, 2026 6:01 pm Hi, After replace the PCM in 2008 Ford F150 4.2L, my Launch Scanner and Forscan are reading a different VIN, I think it is the VIN of donor car. I tried to change it with forscan but it did not show me the PCM module at "Configuration and Programming" section. See the picture. How can I change it? Thank you
