I can't figure out how to disable the door and engine startup chimes. There's a lot of videos and instructions on the internet for the F150 but not the expedition. I've got the basic idea where to make the adjustments in the module but I don't know what numbers I need for the expedition.
The info for the F150 won't work.
In the IPC Module on line 720-01-02 it is currently 240B 1069. Which numbers do I need to change? All the videos etc I find for the F150 just didn't work, I tried their numbers but no luck
2017 expedition turn off door chimes help
Re: 2017 expedition turn off door chimes help
Setting should be in the easy menu of the IPC or BCM. I've done it on a 2015 Expedition, just don't remember where.
