Variable line level preamp output
skylinedan
- Vehicle: fusion 2.7 ecoboost 2017
So I have a 2017 Fusion, I'm changing the outputs from high power to low level so I can feed RCA,s to the DM-810 DSP I have in the back. I went in and changed the third and forth spots in the block to 59 as instructed, but my system sounds the same, not lower sound volume like I was expecting. Any ideas,
Don Ridley
Re: Variable line level preamp output
Look here:
https://www.2gfusions.net/showthread.php?tid=3704
The guys in that forum are you best source for information on your Fusion.
FYI, my 2016 Transit Connect ACM did not have pre-amp outputs. There must be differences in ACMs.
skylinedan
Hey, thanks. I see the problem already, the spread sheet I have doesn't have the last bit in the 727-01-01 block
skylinedan
So after reading the whole tread, I see where people are having issues with buzz at low levels, also he states the 2017 is different from the 16 back, Have yet to find anything on doing this to a 2017 or newer Fusion.
