Hey, I have added a new Key to my Ford Transit V363 via the PATS procedure. Starting the car with the new key works without problems, but using the remote key fob to open/lock the doors does not work. Is this something I need to program separately? I have found contradicting information in the internet, some saying I need to add it via a RKE (Remote Keyless Entry) configuration and some others say it is configured via the PATS procedure. But I cant find any RKE procedures in BCMii or PCM config. Any Ideas? It could also be that my remote key fob is not working because it is not an OEM key but instead a 30$ key from amazon.
Here are my car details:
Ford transit 2.2l, 155ps,
TTG
motor cvf5
Year 31.07.2014
HSN: 8566
TSN: BHO
V363 / TTG
FCD
CVF51 ADX
Van
715/2007*136/2014M
Euro5;M;PI/CI; N1 III, N2
1.7-350L Series
L3H3
remote key fob won't work after adding via PATS
- Vehicle: *** Ford ***
Re: remote key fob won't work after adding via PATS
tilmo wrote: Thu Apr 09, 2026 9:48 am Hey, I have added a new Key to my Ford Transit V363 via the PATS procedure. Starting the car with the new key works without problems, but using the remote key fob to open/lock the doors does not work. Is this something I need to program separately? I have found contradicting information in the internet, some saying I need to add it via a RKE (Remote Keyless Entry) configuration and some others say it is configured via the PATS procedure. But I cant find any RKE procedures in BCMii or PCM config. Any Ideas? It could also be that my remote key fob is not working because it is not an OEM key but instead a 30$ key from amazon.
TTG
motor cvf5
Year 31.07.2014
HSN: 8566
TSN: BHO
V363 / TTG
FCD
CVF51 ADX
Van
715/2007*136/2014M
1.7-350L Series
L3H3
2014 Ford Transit, the remote central locking fob can be programmed manually,
See it this works
https://www.google.com/search?client= ... oe=UTF-8
