How to program add on keypad 2017 F150
gshane
Vehicle: F150 5.0 2017
Post by gshane »
Has anyone programmed a OEM add on keypad 2017 F150, thanks
ebony
Vehicle: 1994 mustang gt
Re: How to program add on keypad 2017 F150
Post by ebony »
GO BACK TO DEALER that keypad is configured for old type iks key not the new switch blade style .the dealer will print you the install guide . i tried using ids (FORD COMPUTER) it said programed but would not work you have to switch remote to other type first then you can program it PITA job :cry:
gshane
Post by gshane »
Thank you for the info, much appreciated, doesn't seam like it is worth the time, thanks again.
