PATS for 2010 FG Falcon
g6e_turbo
Vehicle: fg falcon. 4.0L Turbo. 270kw, 2010
Post by g6e_turbo »
is there any options for PATS on fg, i want to put a different IPC in and it requires PATS to program
KRL-94
Vehicle: 2004 ford falcon 4L inline 6 cyl
Re: PATS for 2010 FG Falcon
Post by KRL-94 »
you will need the hs/ms can switch unit to scan/program on an fg falcon. with that, you should be able to program the ipc. I cant really give anymore info on this tho as I haven't had much experience with fg falcons.
g6e_turbo
Post by g6e_turbo »
yeah i already have the switch to go from HS CAN to MS
gmau69
Vehicle: Ford Falcon BA 4.0L 2003
Post by gmau69 »
Have you found a way to do PATS programming on FG Falcons?
crazy181
Vehicle: 2008 Ford Falcon FG XR6 Turbo
Post by crazy181 »
I have a 2008 FG that i would like to be able to program keys for but so far have not been able to find a way.
When i get a chance i will be sending my logs to the FORscan guys, hopefully support can be added for the FG range. ;)
gmau69
Post by gmau69 »
crazy181 wrote:I have a 2008 FG that i would like to be able to program keys for but so far have not been able to find a way.
Have you tried to program a ICC unit on FG cars?
Does it work the same way like BA/BF where we just select ACM configure?
Rustypick
Vehicle: 2010 xr6 turbo
Post by Rustypick »
Any updates on this?
I have been unable to bring up pats for a 2008 FG Falcon
Vehicle: *** Ford ***
Post by f-wolf »
oldtinfords
Post by oldtinfords »
The FORScan team have advised that key programming on FG mk1 has been added. They need testers to use & provide feedback. Once they are satisfied with the feedback they will start working on FG MK2
gmau69
Post by gmau69 »
Hi, yesterday I tried to perform PATS reset on a 2009 FG and it did not work.
It says I need an ELM (OBD) adapter that could be controlled/switched ( HS-CAN/MS-CAN) by Forscan not manually.
I use ELM with the switch for HS/MS.
Any advice please?
