Mazda Immobilizer Word Code?
Shawnf350
Post by Shawnf350 »
Will Forscan pull up the word code, which is a 8 digit # from the immobilizer unit in order to program a new car key to the system.
If Forscan will pull up the immobilizers code word, that is all that would be needed. The tech programs the system by the security light on the dash with the key in the ignition so just the code word is needed.
2003 Mazda Miata
Thanks,
Shawn
Re: Mazda Immobilizer Word Code?
If you are talking about incode generated by outcode, your tech may try this site:
http://www.autokeyprog.com
