Hi all,
Recently I upgraded from the base 4" screen in my Edge to the 8" MYFord Touch screen. I was successful in the transition. There are a few things I would like to know in Forscan to program.
I keep getting a message when I turn on my car that 911 assist is not operational. Is there a way to disable it? It's a little annoying every time I start my car.
Also, when I try to adjust bass, treble, fade, etc.. it doesn't appear anything happens. I can press the plus and minus buttons on the screen but it never actually goes up or down. Also, if I adjust my volume it will go up and down correctly but doesn't show the little indicator lines on the screen that I actually adjusted the volume.
If someone could kindly post any relevant info to modify these values in Forscan I would appreciate it. If it's not something that can be done in Forscan, please let me know how it can be fixed.
Thanks for any help.
