Failure to load all values in IPMB module
Posted: Wed Nov 08, 2017 12:34 am
Was making changes to my 2016 F150 XLT (USA truck) today and made a backup copy of all modules. Noticed an error when reading the IPMB module:
(OK) [11:18:49.493] IPMB Module configuration (AS BUILT format) has been started
(OK) [11:18:52.170] Read block #1
(OK) [11:18:52.260] Read block #2
(OK) [11:18:52.325] Read block #3
(OK) [11:18:52.381] Read block #5
(WARN) [11:18:52.391] Reading block 6 failed - too large for As Built format
(WARN) [11:18:52.402] Reading block 7 failed - too large for As Built format
I'm using Forscan 2.3.12 Beta. I have previous backups of this module which include Block 6 and 7 being read successfully (includes 7B1-06-01 thru 7B1-06-103 and 7B1-07-01 thru 7B1-07-103). The current version of Forscan only displays Blocks 1, 2, 3 and 5. Is this a known issue or has something changed in the latest release of Forscan? I recently updated to the latest release and now noticed this problem in the IPMB module.
Also notice there is no block #4. However, I don't believe I've ever seen Block #4 read for the IPMB module.
