Mondeo Mk3 will not connect...
Nickmoore1968
Vehicle: Mondeo Mk3 2.2 Tdci
Post by Nickmoore1968 »
I have an 05 Mondeo Mk3 2.2Tdci. I'm using an elm device - usb to serial using prolific driver. Device is on com6. Forscan finds elm device fine but fails to communicate with car even though ignition is on. Other OBD software seems to connect fine but do not have the pats programming function I need. pulling me hair out here, any help appreciated...
Nickmoore1968
Re: Mondeo Mk3 will not connect...
This message appears in the log file:
[Ford Vehicle] Unable to find PCM
So the software knows it is talking to a ford but cannot find PCM? Could this be a fuse issue? would this stop my car from starting and cause PATS code 15?
