Hi FORScan team,
Do you plan to implement many more service functions for Ford Ranger/ Mazda BT50 WE/CD 3litre?
I note you have implemented many service functions for later model 2011 Ford Ranger/Mazda B Series 2.2/3.2
Many thanks in advance.
New Service Functions Ford Ranger Mazda BT50 3.0 WE/CD
Re: New Service Functions Ford Ranger Mazda BT50 3.0 WE/CD
In general case, Ranger/Mazda of 2011 model year has the PCM of latest generation that has much more functions that the previous one, installed on Mazda/Ranger of 2007-2008 model year. What are the functions you would like to see in FORScan?
avkdm
Do you have a list of what is available?FORScan wrote:In general case, Ranger/Mazda of 2011 model year has the PCM of latest generation that has much more functions that the previous one, installed on Mazda/Ranger of 2007-2008 model year. What are the functions you would like to see in FORScan?
I was thinking
Reset all Adaptions
If available individually items listed below
Reset MAF learned values
Not sure if these below apply to Ranger/Mazda BT50 2007/2008
Reset EGR Valve Adaptions
Reset 02 Sensor learned values
Reset Air Intake Throttle Valve Learned Values
Reset Knock Sensor learned Values
Only of course if these are available as I am not familiar with M-MDS functionality.
Unfortunately, this model has quite little of service functions. In addition to programming injectors (implemented in FORScan), we know only 2 function: Reset All Adaptations (PCM reset, used when some components are replaced, details have to be found in workshop manual) and MAF reset.
avkdm
If these other two (Reset All Adaptions and MAF Reset) can be implemented at next or future update, that would be great.FORScan wrote:Unfortunately, this model has quite little of service functions. In addition to programming injectors (implemented in FORScan), we know only 2 function: Reset All Adaptations (PCM reset, used when some components are replaced, details have to be found in workshop manual) and MAF reset.
Thanks FORScan Team!
OK, we have added these features to the queue.
