Hello, having injector issues on original PCM, i replaced by new one.
Flash done with IDS 108 but no way to grant security without OASIS LOCKSMITH access to program smart keys (B10DA:51-0A).
Is there a way to test PATS RESET ?
Thanks helping.
Best regards.
NOTE: This step is only necessary when installing a new component.
Upload the module information from the diagnostic tool using the Programmable Modules Installation routine.
Refer to: Module Configuration - System Operation and Component Description (418-01 Module Configuration, Description and Operation).
Carry out the Parameter Reset procedure.
Refer to: Anti-Theft Key Programming - Scan Tool (419-01B Passive Anti-Theft System (PATS), General Procedures).
Using the scan tool, perform the Misfire Monitor Neutral Profile Correction procedure, following the on-screen instructions.
Hi and thanks helping slippy1990 but i can't carry out the Parameter Reset procedure cause my aftermarket IDS account not allow access security PATS ONLINE for new Ford models.
It is for that i thought that was a way using FORScan to allow this "RESET".
Best regards.
;o)
