Fiesta mk8 compatibility
Is ForScan compatible with the latest Fiesta mk8?
rsford2012
- Vehicle: ford focus st
Re: Fiesta mk8 compatibility
i have just tried to deactivate my Start/Stop... Somehow i can read all data, but when im trying to change them im getting a system error.
Coding the APIM-Module was no problem for me.
I have no idea if i did something wrong or the software isnt supporting the new Fiesta Active 1.0 85hp PCM Module?
arisgardelis
- Vehicle: Ford Fiesta Vignale 1.5 TDCi
I have a Fiesta MK8 1.5TDCi Vignale with B&O sound system. I added the sync3 climate soft and voice controls, but it does deactivate the surround sound. Since music is more important to me, I returned it back to factory setting. I think I also tried to deactivate Start/Stop, but I got an error. The setting was picked up from the F150 settings spreadsheet. It seems that many settings change by themselves if you change another, so be careful and always keep your factory as built settings.
roylion15
- Vehicle: Fiesta ST, 1500, Ecoboost, 200 PK, 2019 model
Same problem here
I can read / write APIMs modules Asbuilt and other config (sync 3) with none problems ..; adding some values for climate screen and no problems.
I can read all others modules, but can't write any modifications in some modules like the IPC by example.
It gives an error when writing a xx % and thus the message "the diagnostic procedure was interrupted"
EU Fiesta ST 2019 model.
O. Van der Enden
- Vehicle: Ford fiesta 2009 1.6 tivct
still have the same problem here, cant get any modules like the ipc programmed, same error
Try the new version of forscan they say that they fixed the problem with IPC
Same problem here.
With the latest version of Forscan i can't write on IPC, the problem wasn't solved.
