A/c P0645 Code
Galaxysong
Vehicle: Ford Transit T280 115 2.2L 2010
A/c P0645 Code
Post by Galaxysong »
Anybody had this fault code?
P0645: A/C clutch relay control circuit, signal stuck low.
Mk7 Ford Transit 2.2 Dciv 2010
Done a resistance test on the A/c pump coil and found continuity.
Also done a mighty fiddly made-up wire and jump lead test on the pump clutch.
The clutch does jump in and out when connecting the leads, so does this confirm the coil and clutch are ok?
Thinking about replacing the relay but was wondering if anybody has come up against this fault before.
The dash switch lights up and the fan kicks in when the button is pressed.
Thanks...
Kelarenik
Vehicle: Ford Focus 3 2.0/150 2012
Re: A/c P0645 Code
Post by Kelarenik »
I encountered the same problem, but changing the relay didn't help. Have you found the cause?
