11 Lincoln MKX
- jessepatty
- Vehicle: 2011 Ford F250 Super Duty 6.7 liter
11 Lincoln MKX
I know most of the as-built programing is interchangeable between platforms, my question is, Which vehicle should I use that closely matches the MKX to make some changes... I can't seem to find anything on the Lincoln MKX itself...
2011 F250 Lariat Ultimate Crew, 176"wb, Powerstroke
2011 Lincoln MKX Premiere W/ Elite package
2003 P71 Police Interceptor
2005 P71 Police Interceptor w/ Trac Lok
Re: 11 Lincoln MKX
Anything in particular you are trying to turn on or off?
My father has a 2011 MKX premium package. So I have a list of options it came with and can help decipher the asbuilt if it’s something you are trying to add
I would think the Explorer would be closest to compare asbuilt data. But with other spreadsheets out there I’d compare all
- jessepatty
Re: 11 Lincoln MKX
Primary I want to enable the windows up with the remote as well. The windows down with the fob is already enabled and I know both can be enabled.
Secondly, I want to increase the lane change turn signal count from 3 to 5.... I did this to my SD and really like the additional flashes.
I also want to switch the compass in the right LCD to the turn by turn nav directions.... I know that is a configurable option as well..
I want to go through all of it and make adjustments as I did with my Super Duty more or less to make it look and do what I want.
Re: 11 Lincoln MKX
You can follow the 2011-2015 Explorer ForScan mods. Most of them apply.
For global close, I enabled it on my 2011 MKX: http://www.fordedgeforum.com/topic/2303 ... -2015-mkx/
Also I was able to disconnect a wire to prevent the sunshade from opening & glass roof venting when. Using global open. Note that with global close, only the front windows closed, but not the vista sunroof:
http://www.fordedgeforum.com/topic/2382 ... -location/
- jessepatty
Re: 11 Lincoln MKX
Thank you . I'll check it out when I get home. Much appreciated
- jessepatty
Re: 11 Lincoln MKX
I found with mine, when I global open via remote, if I hit the lock button once quick and then again and hold, it only opens the windows. If I then hit lock again and hold, it opens the roof... The roof doesn't automatically open on a global open request from the fob w/o the third lock and hold push... It's working exactly like my brothers BMW functions, steps wise.omar302 wrote: Sun Aug 26, 2018 9:35 am You can follow the 2011-2015 Explorer ForScan mods. Most of them apply.
