Programming
RudePhil
Vehicle: F150 XLT 3.5 Ecoboost Crewcab 2015
Programming
Post by RudePhil »
Hello to all. I'm new here and I'd like to do some changes to my 2015 F150. I paid for the Forscan Lite, I see the spreadsheet for the changes I will like to make,but....when I connect my unit to the OBD I find it on my Android phone. It shows connected with an exclamation mark saying internet may not be available.....with that said when i open up Forscan Lite nothing shows up far as information about my vehicle.....The unit i purchased connects through WiFi and has a switch on it.....Can someone lead me in the rite direction please. Thanks in advance.
invigilator
Vehicle: 3.5L GTDI 10R80
Re: Programming
Post by invigilator »
Never used FORScan on Android device but if you are going to change any configuration, I'd suggest you using the windows version.
Andyfocus
Re: Programming
Post by Andyfocus »
did you try it with the switch in a different position ? , should be set to hs then it will ask you to change to ms after a moment when its read the modules on the hs .
