I have noticed there is an option under service procedures for my 2009/59 Mondeo MK 4 TDCi for headlight initialisation - does this perform the headlight autolevel reset function needed for Bi Xenon headlights when disconnecting the battery or is this for something else? If not, is there any plans to implement this in Forscan?
Thanks!
Bi-Xenon Headlight initialize
Re: Bi-Xenon Headlight initialize
Yes, it does. Also, it is used to adjust the bean using special equipment, but if you have one adjusted, you can just click OK and pass this step.bigi wrote:does this perform the headlight autolevel reset function needed for Bi Xenon headlights when disconnecting the battery
bigi
- Vehicle: Mondeo Mk5 Titanium 2.0TDCI 180, 2016 (66)
great - what special equipment does it require? standard beam setting equipement (MOT type), or something else?
We believe any standard equipment should be OK.
