injector coding
simran
injector coding
Post by simran »
Hi all, I have a ford fiesta 1.4 tdci on a 2008 plate, if i am replacing any of the injectors, is it a case of just fitting the new ones or programming the new injector(s)?
Thank you
Re: injector coding
If you replace any of the injectors (or all of them), you have to program new injector code(s) in PCM. FORScan should have this function implemented for your model.
simran
Re: injector coding
Post by simran »
Thank you for your reply. The codes which are needed to program the injector, are they found on the injector it self?
thanks
Re: injector coding
Yes, the code should be available on the injector's body
simran
Re: injector coding
Post by simran »
Ok tkank you
