I was wondering if it is possible to do a ABS Service Bleed for my 2006 F150 4x4 5.4?
I'm sure there would be a ton of interest for this feature since it is not possible to do without a dealer specialty service tool. I did notice that under the ABS tab (Windows version) I can toggle from "Read" to "Control". Does that let me manually control the ABS valves?
Thanks a lot, this software looks very helpful.
-Mike
ABS Service Bleed for F150
Re: ABS Service Bleed for F150
ABS service bleed function is not implemented for F150 yet... The problem is that these functions are different models, so we have to implement them individually. Yes, theoretically you can use Output Control function to manage the valves, but not all of necessary actuators may be available there, also you should know right sequence of actions. So we would recommend to wait for a service function. If you are ready to be a beta tester for this function, we can add it to the development queue.
