reading mk5 fiesta abs module
PeterS
Post by PeterS »
Can anyone tell me if the latest 2.2.2 version of FORScan should able to read the codes from the ABS module of a Ford Fiesta mk5 2005 1.4 TDCI?
At the moment I have abs warning light on but no codes are read. It picked up 2 PCM codes. Another reader picked up that 3 ABS sensors are faulty (mechanic said probably a faulty ABS module circuit)
Many thanks,
Pete
Re: reading mk5 fiesta abs module
Yes, FORScan should be able to read DTC codes in ABS module on this model. Does FORScan find the ABS module at all (Vehicle->Configuration or Vehicle->Modules)? If no ABS module is found after connect, please remove the vehicle profile (Vehicle->Profiles) and try again. If ABS modules is still not found, it most likley means there is a problem in ISO circuit of your adapter (PCM, TCM and Instrument Cluster are on CAN bus, but ABS, GEM and Airbag are on the ISO bus).
