DPF temperature
bozda
Vehicle: Ford Focus, 2.0 Tdci, 100kw, 2007
DPF temperature
Post by bozda »
pls where i could find PID for DPF temperature? I found only DPF diff pressure in Forscan. I need also temp which indicates DPF regeneration.
Re: DPF temperature
There should be a EGT PID. But it measures not DPF temperature but exhaust gas one.
bozda
Re: DPF temperature
Post by bozda »
EGT pre a post catalyst, but from these temperatures i cannot decide when DPF start to regenerate..:(
bozda
Re: DPF temperature
Post by bozda »
So DPF temperature is not avialable in FORScan diagnostic tool?
Re: DPF temperature
bozda wrote:So DPF temperature is not avialable in FORScan diagnostic tool?
Seems so.
