TPMS ID's
jdcmax
Vehicle: Ford C-Max Energi, 2013
TPMS ID's
Post by jdcmax »
I see the same problem on the Lite version on the iPad and the Windows version. Vehicle is 2013 C-Max Energi.
Here are the 4 values received from the car from the Body Control Module:
358E87A6, 358D3B9B, 358E87BC, and 358D3BE3
Here are the 4 values shown by FORScan (in hexadecimal)
898533312 (358E87C0)
898448256 (358D3680)
898448384 (358D3C00)
As you see it seems to be rounding off the least significant bits before converting to decimal and some other weirdness I don't understand ;)
Re: TPMS ID's
Can you please specify what exactly PIDs show these values? Thanks.
jdcmax
Re: TPMS ID's
Post by jdcmax »
FORScan wrote:Can you please specify what exactly PIDs show these values? Thanks.
Module 726
Mode 22
PID's 280F through 2812
Re: TPMS ID's
Current version of FORScan is not designed to display this type of PIDs in Dashboard. First, it should be displayed as a hexadecimal and not converted. It is currently converted from 4-bytes integer to float and then back to integer, and loses on this conversion because float type has no enough precision.
These PIDs are internally used in service functions and tests, we usually disable them in Dashboard, as they do not make much sense to be displayed in Oscilloscope etc. What is the necessity, in your specific case, to get TPMS IDs in Dashboard?
jdcmax
Re: TPMS ID's
Post by jdcmax »
The tire pressures were identical (like 3.07 Bar) on two of the tires, I just wanted to make sure the car had the 4 unique TPMS ID's stored. The dashboard is the only place I knew of where I could see, are they available somewhere else?
Re: TPMS ID's
At this moment - there is no other place... In the future versions this information will be either available in the vehicle configuration information, or in special test/service functions. We will also think on displaying them properly in Dashboard in one of next versions...
jdcmax
Re: TPMS ID's
Post by jdcmax »
Vehicle configuration information sounds like a good idea since they aren't a varying quantity. Ideally Ford would have displayed the TPMS pressures on one of the three LCD screens :(
jdub1981
Vehicle: 2013 Focus ST 2.0 Turbo
Re: TPMS ID's
Post by jdub1981 »
jdcmax wrote:Vehicle configuration information sounds like a good idea since they aren't a varying quantity. Ideally Ford would have displayed the TPMS pressures on one of the three LCD screens :(
Ive added these a few months ago to Torque. They work great for getting the exact value for each tire on the 2013 Focus ST.
