Traffic sign recognition on Fiesta MK8 >2017
c.piano
Vehicle: Fiesta MK8 1.5 85cv
Post by c.piano »
Hi to everybody, iv just change parameters on IPC and i have now the menu on IPC. But now what parameters i have to edit on IMPA?
I though
706-01-01 xxxx 55A9 xxxx
on 706-01-01 xxxx 55B2 xxxx but it doesnt work.
have any idea?
Dragunov
Re: Traffic sign recognition on Fiesta MK8 >2017
Post by Dragunov »
Not yet...
Here on the IPC, both circles are active now aswell, but the IPMA needs to give the data to the system now
I wonder if there are different versions of the IPMA used?
c.piano
Post by c.piano »
I don’t understand what you mean...
With the activation on IPC I have the menu and the possibility of activate the tsr but with only empty 2circles.
To activate all you have to change parameter on impa but I don’t know what parameters have to write...
gg1234635
Post by gg1234635 »
Silly question but you do have sat nav working in your car?
I lost my sat nav for some unknown reason and lost sign recognition on my IPC unless the camera picked up a speed sign.
So not only do you need to activate that feature you also need a working sat nav
c.piano
Post by c.piano »
I have working sat nav. After the changed parameters on IPC I have the empty circles on the right of display. I need only to change parameters on impa I think.
But I don’t know what sector I have to edit
gg1234635
Post by gg1234635 »
send me a message with your VIN number so i can look up its as built coding and then i can compare it against my mondeo and see if i can spot anything and get back to you if i do.
c.piano
Post by c.piano »
Pm sent but we don’t understand what kind of parameters have to change.
Anyone know solution?
roylion15
Post by roylion15 »
@C.piano
Can you explain how to add TSR in the IPC menu with forscan on the mk8 ?
For IPMA 706-01-01 you have xxxx 55A9 xxx as me , on another MK8 vignale 2018 as built with factory TSR, the value is xxxx 99DA xxxx
c.piano
Post by c.piano »
“Writing block failed” - incompatible configuration.
Isn’t possible change 706-01-01. Damn
c.piano
Post by c.piano »
I will write what need to change in ipc, now I have to go work... tomorrow and I will exit from work at 21.30 Italy. Tomorrow I will write you what need to change in IPC
