I would like to request access to the latest FORScan beta version for advanced programming.
My car is a 2015 Ford Mondeo MK5 1.5 TDCi with manual transmission.
I’m planning to restore factory settings and possibly perform firmware updates.
Thank you very much.
Request FORScan Beta with Extended License
oldtinfords
Re: Request FORScan Beta with Extended License
To get access to the latest beta version, you need a paid licence. This will give you an invite code to access the forums where the Private beta topic is. The download link is pinned in hte first post. https://akm-software.org/said10 wrote: Sat Aug 02, 2025 9:51 pm Hello,
Steering Wheel Audio Controls Not Working After Configuration Change
I was changing some configuration settings on my Ford Mondeo (MK5, 1.5 TDCi, 2015, manual) using FORScan, and after that, the steering wheel audio control buttons (volume up/down and mute) stopped working.
Could you please help me restore the correct settings so that the steering wheel buttons work again?
Thank you in advance for your support. WF0FXXWPCFFJ52484
oldtinfords
Use the asbuilt data you saved before starting to make any changes to restore the function.said10 wrote: Tue Aug 19, 2025 5:55 pm Hello,
- LaForge
- Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
- Contact:
I guess you can SET to Factory Default on the bottom of the screen.
Then the original AsBuilt will be loaded and installed.
Changed on my 2011 Focus:
