after I wrote the original As Built from my analog IPC to the digital IPC from the fiesta mk8.5 I lost the ability to see tire pressure information and location, is this not available on the digital IPC's?
it's an IPC from a mk8.5 in a mk8
TPMS locations gone after programming digital dash
boosted_diesel
Re: TPMS locations gone after programming digital dash
Have you checked in the programming and configuration to see if it's an option to switch it on? It may have been switced off on the donor car or could come new with that setting off. Maybe just needs switched on.
Don Ridley
Try the as built from the digital IPC. Hopefully someone has already researched and determined the key as built data. Otherwise you have some work ahead of you.
problem is resolved, turns out I still had the TPMS by location option off in the IPC settings, I didn't see it.
my bad
my bad
boosted_diesel
Aw well, there you go
