Hey there,
it happened a few times, now more often. While driving, sometimes there is a massive loss in power (getting slower on Autobahn/highway) and shortly after like the whole dashboard is acting up, SBS disabled, Driver Altert disabled etc, car has no power anymore, shifts really rough. I've dumped a log. Simply turning the car off and on again sovles the issue so far, but I wanted to ask for your opinion what I may can do about it?
===TCM DTC U0442:00-2F===
Code: U0442 - Invalid Data Received From ECM/PCM B
Status:
Module: Transmission Control Module
Freeze Frame #1:
-DTC: --- - DTC That Caused Required Snapshot Data Storage
-LOAD: 61.18 % - Calculated Load Value
-ECT: 90 °C - Engine coolant temperature
-RPM: 2023 1/min - Engine Revolutions Per Minute
-VSS: 106.0 km/h - Vehicle Speed
-IAT: 30 °C - Intake Air Temperature
-TP: 81.96 % - Throttle Position
-RUNTM: 321 s - Time Since Engine Start
-VPWR: 13.65 V - Control Module Voltage
-APP_D: 51.76 % - Accelerator Pedal Position D
-APP: 51.50 % - Accelerator Pedal Position
-SLIP_VALUE: 48 1/min - Absolute Value of Slip
-HTM_DIS: 0.0 km - The distance travelled since the High Temperature Mode was activated.
-PADDLE_DOWN: Off - Paddle Shift - Down
-PADDLE_UP: Off - Paddle Shift - Up
-TR: error - Transmission range
-GEAR_SEL: 6 - Gear select position
-TSS: 1979 1/min - Turbine Shaft Speed
-OSS: 3295 1/min - Output Shaft Speed.
-TFT: 82 °C - Transmission Fluid Temperature
-LOCK_UP: ON - Toruque Converter Lockup State
-MST_REC_SFT: 5 to 6 - Most Recent Shift Event
-SE_TYPE: Bf_5th Af_6th - Most Recent Shift Event Type Identifier
-SC_STATE: Active - Shift On Control Status
-SFT_CTL_STS: Active - Shift On Control Status
-OIL_PRES_SW2: On - Oil Pressure Switch 2
-OIL_PRES_SW1: Off - Oil Pressure Switch 1
-OP_SW2: On - Oil Pressure Switch 2
-OP_SW1: Off - Oil Pressure Switch 1
-SS_ON_OFF: Off - ON/OFF solenoid
-SS_ON-OFF: Off - ON/OFF solenoid
-EOP: Off - Electric Oil Pump
-TORQUE_DES: 460.0 Nm - Desired Engine Torque
-G_INHIBIT_R: Off - Gear Inhibit - Reverse Range
-G_INHIBIT_N: Off - Gear Inhibit - Neutral Range
-G_INHIBIT_6: Off - Gear Inhibit - 6th Gear
-G_INHIBIT_5: Off - Gear Inhibit - 5th Gear
-G_INHIBIT_4: Off - Gear Inhibit - 4th Gear
-G_INHIBIT_3: Off - Gear Inhibit - 3rd Gear
-G_INHIBIT_2: Off - Gear Inhibit - 2nd Gear
-G_INHIBIT_1: Off - Gear Inhibit - 1st Gear
-OIL_PRES_SW4: On - Oil Pressure Switch 4
-OIL_PRES_SW3: Off - Oil Pressure Switch 3
-EOP_RLY: Off - Electric Oil Pump Relay
-OP_SW4: On - Oil Pressure Switch 4
-OP_SW3: Off - Oil Pressure Switch 3
-UPSHIFT_REV: On - Upshift Record By Engine Request
===END TCM===
===PCM DTC P0299:00-26===
Code: P0299 - Turbocharger/Supercharger "A" Underboost Condition
Status:
Module: Powertrain Control Module
===END PCM===
===PCM DTC P117A:00-28===
Code: P117A - Engine Oil Overtemperature - Forced Limited Power
Status:
- Previously Set DTC - Not Present at Time of Request
Freeze Frame #1:
-LOAD: 99.22 % - Calculated Load Value
-ECT: 95 °C - Engine coolant temperature
-RPM: 1630 1/min - Engine Revolutions Per Minute
-VSS: 68.0 km/h - Vehicle Speed
-IAT: 21 °C - Intake Air Temperature
-MAF: 18.44 g/s - Mass Air Flow
-ISV_POS: 81.96 % - Intake Shatter Valve Position
-RUNTM: 807 s - Time Since Engine Start
-FRP: 117340.0 kPa - Fuel Rail Pressure
-FLI: 20.00 % - Fuel Level
-WARM_UPS: 9 - Number Of Warm-ups Since DTCs Cleared
-CLR_DIST: 651.0 km - Distance since diagnostic trouble codes cleared
-BARO: 97.0 kPa - Barometric pressure
-VPWR: 13.76 V - Control Module Voltage
-TP_REL: 82.35 % - Relative Throttle Position
-AAT: 21 °C - Ambient Air Temperature
-APP_D: 56.08 % - Accelerator Pedal Position D
-APP_E: 56.08 % - Accelerator Pedal Position E
-TAC_PCT: 82.35 % - Commanded Throttle Actuator Control
-ISV_DSD: 82.35 % - Intake Shatter Valve Control Desired
-FUEL_TYPE: DSL - Type of fuel currently being utilized by the vehicle
-FRP_ABS: 117340.0 kPa - Fuel Rail Pressure (Absolute)
-APP_REL: 56.08 % - Accelerator Pedal Position Relative
-EOT: 98 °C - Engine Oil Temperature
-ECT2_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT1_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT2: 135 °C - Engine Coolant Temperature 2 - Voltage
-ECT1: 95 °C - Engine Coolant Temperature Sensor 1
===END PCM===
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII===
===HUD_MZ DTC ===
Module: Head Up Display
===END HUD_MZ===
===AM DTC ===
Module: Amplifier Module
===END AM===
===CMU DTC B108E:04-0B===
Code: B108E - Display
Additional Fault Symptom:
- System Internal Failures
Status:
Module: Connectivity Master Unit
===END CMU===
===CMU DTC B119F:92-08===
Code: B119F - GPS Antenna
- Performance Or Incorrect Operation
Status:
===END CMU===
===SBS/MRCC DTC U0301:09-8A===
Code: U0301 - Software Incompatibility with ECM/PCM
- Component Failures
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Smart Brake Support/Mazda Radar Cruise Control
Freeze Frame #1:
-ECU_POWER_SUPPLY: 13.8 V - ECU Power Supply Voltage
===END SBS/MRCC===
===SBS/MRCC DTC U0316:09-8A===
Code: U0316 - Software Incompatibility with Vehicle Dynamics Control Module
Status:
Freeze Frame #1:
===END SBS/MRCC===
===ABS DTC U0401:00-8A===
Code: U0401 - Invalid Data Received From ECM/PCM 'A'
Status:
Module: Antilock braking system
===END ABS===
===EPB DTC ===
Module: Electric Parking Brake
===END EPB===
===DCDC DTC ===
Module: DC to DC Converter Control Module
===END DCDC===
===DSM DTC ===
Module: Driver's Seat Module
===END DSM===
===RCM DTC ===
Module: Restraint Control Module
===END RCM===
===AFS/ALM DTC ===
Module: Adaptive Front Lighting System / Auto Leveling Module
===END AFS/ALM===
===SSU DTC B13D3:16-08===
Code: B13D3 - PATS Transmitter
- Circuit Voltage Below Threshold
Status:
Module: Start Stop Unit
Freeze Frame #1:
-EVENT_TIME: 266773718 s - Event time
-TOTAL_DISTANCE: 209861 km - Total Distance
-MODULE_VOLTAGE: 12.8 V - Control Module Voltage
===END SSU===
===EPS DTC ===
Module: Electronic-Controlled Power Steering
===END EPS===
===F_BCM DTC ===
Module: Front Body Control Module
===END F_BCM===
===IC DTC ===
Module: Instrument Cluster
===END IC===
===FSC DTC U0401:68-0A===
- Event Information
Status:
Module: Forward Sensing Camera
Freeze Frame #1:
-ECU_POWER_SUPPLY: 13.9 V - ECU Power Supply Voltage
===END FSC===
===FSC DTC U0415:68-0A===
Code: U0415 - Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
- Event Information
Status:
Freeze Frame #1:
===END FSC===
===BSM DTC ===
Module: Blind Spot Monitoring
===END BSM===
===R_BCM DTC ===
Module: Rear Body Control Module
===END R_BCM===
===PSM_MZ DTC ===
Module: Parking Sensor Module
===END PSM_MZ===
===EATC DTC ===
Module: Electronic Automatic Temperature Control
===END EATC===
Mazda 6 2.2 175d - Loss of power until engine started again
Re: Mazda 6 2.2 175d - Loss of power until engine started again
Hi, I'm facing the exact same issue - P0299 (Turbo/Supercharger “A” Underboost)
Turbo makes whining noise under 2,500rpm and after that it kicks in properly and boosts fine.
After driving for some more time, lights are lit with xmas lights on dashboard, TMPS, SMBC malfunction etc.
boosted_diesel
It’s going into limp mode due to the engine oil getting too hot.
It also has an underboost code which could be caused by a boost leak or other issue.
Those engines have a lot of common problems, I would check the engine oil level and see how dirty it is. They tend to blow the injector seals and fill the oil up with soot assuming it’s a 2.2 skyactive.
Mareng
- Vehicle: Mazda 6 Diesel, 2.2, 2014, Britain
Looks more like a coolant temperature problem as thats far higher and they are usully quite close as the coolant cools oil.
By all means check condition of oil, level, colour and feel, rub some between finger and thumb, it is harmless as long as you clean your hand and wash them in hot soapy water.
If coolant temp is going up have you checked yot header tank when cold. When hot is it spitting frommthe header tank, could be sign of Head gasket failing, unusual on a disel unless laboured a lot on hills or if towing.
boosted_diesel
The answer is in the dataFH2k wrote: Sun Apr 13, 2025 7:35 am
Status:
Freeze Frame #1:
===END PCM===
