Increase Indicator/ blinks before cancel MK8 Fiesta
a7mag3ddon
Vehicle: Fiesta, 1.0 Ecoboost, 2018
Post by a7mag3ddon »
Does anyone know if it's possible to change the number of blinks/ indications from 3 to something higher. I could have sworn I saw this setting somewhere either on BCM or SCCM but it's not there when I've gone back.
I read on a Ford F150 it can be done by as built but my car is a MK8 2018 Fiesta and didn't want to try editing from a different vehicle.
Any help appreciated.
Joh150413
Re: Increase Indicator/ blinks before cancel MK8 Fiesta
Post by Joh150413 »
I don't know about the Fiesta but, in F150 and Taurus it is in the SCCM. 724-01-01 XXXX-X*XX-XXZZ. 0-3 = 1 Flash, 4-5 = 2 Flashes, 6-7 = 3 Flashes, 8-9 = 4 Flashes, A-B = 5 Flashes, C-D = 6 Flashes, E-F = 7 Flashes. Change the *. If you have a 6 change to 8, if you have a 7 change to 9 and so forth. Ignore the warning about the checksum, ZZ, and continue.
a7mag3ddon
Thanks, I'd seen the F150 instructions before but reluctant to try it on a different model vehicle in case it messes something up.
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley »
a7mag3ddon wrote: Sun Jan 18, 2026 2:55 pm Thanks, I'd seen the F150 instructions before but reluctant to try it on a different model vehicle in case it messes something up.
Backup all the modules. Verify your backup.
But I doubt the F150 settings will work. The vehicles are on different data platforms/architecture The only crossover seems to be the ACM since.it is common to many vehicles.
Joh150413
Post by Joh150413 »
Well, if it was me, I'd look at 724-01-01 and see if the 6th character is 6 or 7. If so, change to the corresponding character for the increase you want. If the flash count changes, all good. If it doesn't, revert to the original value.
a7mag3ddon
Yeah I'm going to, I forgot my laptop today but I'll check it and report back tomorrow.
a7mag3ddon
I had the letter B which is supposed to be for 5 flashes but it's not, it's current flashing 3. I changed it to C which should have increased it alot (from 3) but didn't so I don't think it's compatible.
a7mag3ddon
It alters the Wash Before Wipe time
miles5600
Vehicle: fiesta MK8 2018
Post by miles5600 »
any update on this? I'm also looking to change this.
a7mag3ddon
Sadly no update, I don't think it can be done. Last thing I've read somewhere is if the car thinks there's a trailer attached it makes the flashes longer however that probably causes all sorts of other issues, trailer setting from memory is in the BCM. Enable and see if it works, I'll be trying myself at some point but I bet it complains it can't see the bulbs on the trailer and all kinds of stuff.
