Test on 1998/1999 Transit 2.5 TD EPIC
Nono 57
Vehicle: 1999 Transit TD 2,5 (EPIC system)
Post by Nono 57 »
I test and use (the excellent ! ) FORSCAN on my Transit Mk5 2,5 TD with EPIC injection system.
I also tryed it on others similars models of Transit.
The first feedbacks :
From 1992 to middle 1997 models, it wasn't run and can't connect to vehicle (2 models tested). :( But from middle 1997 to end of production, due to Euro II / EEC97 LDT compliance, it's run nicely. (2 vehicules tested) :D With the VIN number and the ETIS ford website, you can check the vehicule emission compliance level before any purchage.
The DTC's seem's corrects and true. On one vehicule, I had a trouble code, and after inspection, it's effectively the good problem.
But resetting trouble codes can be a source of confusion. I dont know if it's only on french version ? But when you clear the code, you dont have any feedback and sometimes a failure message (but DTC's are really cleared).
The oscilloscope run well. The bolt up refresh rate look little slow ?
A great feature may be implemented : the boost sensor ?
Best regards.
PS : sorry for my English, I try to do the best I can.
