Activating 12 volts on trailer connector via forscan?????
jfjk
Vehicle: F150, 5.0L, 2015
Post by jfjk »
On newer F150, the 12 volts on the trailer connector is not always on (you dont have lights in your trailer if your truck is not running). I was wondering if we could change a value in some module to tell the truck to have this output always on, on the F250 ant up they are always on, it's maybe a wiring thing but I wont know if I dont ask... lol
Thanks everyones.
sootie
Vehicle: 2011 F250 XL, diesel 4x4
Re: Activating 12 volts on trailer connector via forscan????
Post by sootie »
i also wonder if this can be done by programming. i have figured out a way to do it with hard wiring but i hate modifying factory harnesses. The problem with hard wiring is the truck thinks there is a trailer attached all the time and so every time you put the truck in gear the "trailer connected" message pops up on the dash
jfjk
Post by jfjk »
I finally decide to install a jumper and a switch on the trailer tow module. I've took the input power (pin 1) and connected to the output (pin 3) with a switch to avoid someone turning my light on the trailer and killing my battery!!!
Simple and no message!
1 foot of wire and 1 switch!!!
The trailer tow module is located just over the park brake pedal!
Trailer mod.jpg (223.5 KiB) Viewed 3719 times
