FORScan Lite Beta for Android
hiej
Vehicle: 2010 Mazda 3 - 2.2d 136KW
Post by hiej »
Ok received the text by mail.
I send back to you translated ia a couple of days ;)
carlus
Vehicle: MAZDA CX7 MZR CD 2.2 2010
Post by carlus »
FORScan wrote:
skauber wrote:I think it would be good to implement an alarm like that as well, even if it only works when the app is in the foreground, as to alert a driver if some value goes too high or too low when hes busy looking at the road and not the app. :)
As mentioned previously, this feature is planned to be implemented in future releases, will not be included in the first release.
This option is also quite interesting as it avoids having to look at the screen of the mobile when you're driving.
The idea is that if you want to control , for example , when a DPF regeneration occurs or if you 're going through a certain speed , the phone rings ... and then you realize that "something" happens .
I wish development plan soon.
A greeting.
MAZDA cx7 diesel
spektr
Vehicle: mazda 6 2.2
Post by spektr »
Maybe i missed this, but is it possible to execute service procedure through forscan for android?
fred08155
Post by fred08155 »
Yes - you missed it. There are no extended functions in the android and iOS versions.
The developers say it is unsafe. On android the apps can be stopped / ended any time by memory management for example. If this happens in the middle of a timing critical service procedure...
spektr
Post by spektr »
Ok, i get the picture. Bot on the other hand, i occasionally have such cases on windows platform. Especially when injector calibration is going on. But this still can be solved with little patience and time :-)
szemisun
Vehicle: Ford Mondeo Turiner MK4 2.0 TDCi 163 Hp 2011
Post by szemisun »
Hello
Would you send me the resource file, because i would like to help you to translate it to hungarian.
btw, this app is fantastic, i love it!
Thanks,
G
13313888066
Vehicle: ford kuga,2.0,2013
Post by 13313888066 »
GOOD
veeefour
Vehicle: 2015 Mustang GT
Post by veeefour »
For some reason I can't save to CSV on my phone. It saves to FSL without any problems but when I try to save to CSV it throws "unable to save".
I have FORScan folder in Download and I can copy the FSL files - wont save to CSV.... :cry:
HTshow
Vehicle: 2015 350NM
Post by HTshow »
Thank you very much
cubanB
Vehicle: Ford Edge 2011 Limited 3.5L
Post by cubanB »
veeefour wrote:For some reason I can't save to CSV on my phone. It saves to FSL without any problems but when I try to save to CSV it throws "unable to save".
I have same problem. Android 7.0. it can save .fsl files but .csv files it gives the error unable to save file. Is there a separate application this export is dependent on? Also any way to convert.fsl to csv? Haven't tried it myself yet
