2017 F150 Navigation
is there way to reprogram the nav system to work while moving like can do on older Sync 2 models?
lenko
- Vehicle: 2015 Lincoln MKC(Sold), 2006 Mustang GT, Saleen 530 HP
Re: 2017 F150 Navigation
- Untitled.jpg (45.12 KiB) Viewed 2417 times
thanks ill give that a try under the APMI
thanks
Nope that didn't work that's on the Sync2 format. I have the Sync 3 updated version the screen shot shown isn't any the options listed on the actual module.
lenko
https://docs.google.com/spreadsheets/d/ ... edit#gid=0broome101 wrote: Wed Feb 20, 2019 9:09 pm Nope that didn't work that's on the Sync2 format. I have the Sync 3 updated version the screen shot shown isn't any the options listed on the actual module.
in APIM try 7D0-02-01 x7xx xxxx xxxx.
Didn't work either I saw on the spreadsheet should be didn't work. ill try again tomorrow to change back and the add again see what happens. It worte it cause when I double checked it was 5753
After doing reset then doing it over she took and works perfect now. Thanks.
