Region And Language for APIM and IPC
sikor00
Vehicle: Ford, mondeo mk5
Re: Region And Language for APIM and IPC
Post by sikor00 »
I changed in my Ford Fusion 2016 Hybrid IPC and APIM to PL 504C and in clocks I still have English, Spanish and French. Do you still need to change something? How do you need some update, where to get files from? Please help.
cody25
Vehicle: Fusion, 2.0, 240KM, 2014
Post by cody25 »
Hello, I have a problem with the self-changing language from Polish to English in Sync 2 (version 3.08). The patient is Ford Focus ST from 2014 from the USA. The system has been updated to the Polish version soft and the region on PL has been moved to forscan. Could it be the faults of the odometers (picture) that they are in English? There is no Polish option there ;( maybe some ideas? How to add a Polish language in them?
marekrumin
Vehicle: FORD ESCAPE 182KM 2014
Post by marekrumin »
Pl na zegary to 720-01-01 0000 2142 8C
marekrumin
Bardzo dziękuję za pomoc
Geri89
Vehicle: Ford Focus 2015 1.5TDCI 120
Post by Geri89 »
Hello! I have a 2015 Ford Focus MK3.5 (European version). It has a Sync 2 system. I would like to turn Hungarian language. How can I do this?
Thanks!
_TrotyL_
Vehicle: TRANSIT TDDI 23.0
Post by _TrotyL_ »
marekrumin wrote: Fri Sep 13, 2019 11:34 am Pl na zegary to 720-01-01 0000 2142 8C
Hello!
Mam RS'a '16 USA , 0000 xx00 , to prawda , zmiana tych wartosci i zatrwierdzenie przynosi natychmiastowy efekt zmiany jezyka w szafie niestety "2142" jakies egzotyki mi laduje. Po omacku staralem sie wstrzelic w polski , niestety bez efektu,
Prosze o pomoc w tej sprawie...
Pozdrawiam!
That's true, when I change "xx" value 0000 xx00 my cluster restart with other language but not polish.
The car is Focus RS USA '16 .
Thanks for help with this conversion.
Greats,
_TrotyL_
Saif
Vehicle: Ford f150 2018 ecpost 6 cylander
Post by Saif »
eng_mhd wrote: Wed Feb 21, 2018 2:47 pm I know the region for USA is 5553
For Canada is 4341
For Japan is 4A41
But need the code for Saudi Arabia. Middle East, And UAE
Hi. My vehicle from us region and i uesd in gcc what code i have to change to make it work i dowinlod gcc map but dosnt work
omar302
Post by omar302 »
Saif wrote: Sun May 24, 2020 7:56 am
For Canada is 4341
For Japan is 4A41
Follow the image form the 1st page.
Qatar is QA (I know this is correct). So you will need to change it 5141 (Q=51, A=41)
Saudi Arabia would be SA, so it is 5341.
For the maps, if it is Sync2 (MyFord Touch), there is no maps for GCC. If Sync3, you first have to have a Sync3 that originally has NAV, you cannot add NAV because the hardware doesn't have enough memory.
Saif
Post by Saif »
Thank for reply The Gulf map was installed on the system, but now it show fault in niv . I think it needs to change the country code in the system to work. I cannot return the old map to avoid fault.
omar302
Post by omar302 »
Saif wrote: Sun May 24, 2020 2:31 pm Thank for reply The Gulf map was installed on the system, but now it show fault in niv . I think it needs to change the country code in the system to work. I cannot return the old map to avoid fault.
Sync2 or Sync3? How did you install GCC maps?
