REMOTE START
REMOTE START
Hi !
Remote start the car ( Ford S-Max 2.0 TDCi 2017 PowerShift )
4Button Remote smart Key 433 or 434 MHZ DS7T-15K601-EF (please see ford etis )
guide for Ford S-Max mk2
To activate Remote Start, first you need a new key fob with start button (part # DS7T-15K601-EF for S-Max mk2 with 434 MHz).
:!: Note ! remove the metal blanks from the keys, the car doors are closed and the handbrake deactivated.
Programming keys
:arrow: Place the first programmed key in the backup slot. Press the START / STOP button.
:arrow: Within 5 seconds, place the second programmed passive key in the backup slot, then press the START / STOP button.
:arrow: Within 5 seconds, place the unprogrammed passive key in the backup slot and press the START / STOP button.
Congratulations on your new key being programmed !!! :)
Now use Forscan to change the asbuilt-data
BCM module- configuration parameters
• Remote start - enable
IPC module - configuration parameters
• Remote start - climate settings- enable
• Remote start - front seat- enable (optional)
• Remote start - rear defrost – enable (optional)
• Remote start - steering feel – enable (optional)
some guides recommend
RTM module - configuration parameters
don't change anything :!: ( old keys can also be used in the future )
b3nyf
Vehicle: smax 2.0 diesel 210bhp 2016
Re: REMOTE START
Post by b3nyf »
Hi.
Does the ford pass app work with this? Or is it keys only. Thanks
Re: REMOTE START
ReNeGaDo
Vehicle: S-max 2.0 tdci 190 '19
Re: REMOTE START
Post by ReNeGaDo »
fordsmax471 wrote: Tue Dec 17, 2019 6:19 pm Hi !
Remote start the car ( Ford S-Max 2.0 TDCi 2017 PowerShift EU )
4Button Remote smart Key 434MHZ DS7T-15K601-EF
Programming keys
Well well, first of all thank you ! For sharing this for all of us, Ive just bought an Smax 2019 model that doesnt have the sync 3 hardware needed to start the car remotely.
In my personal case ( car in the sun south of Spain... , 2 little kids) this is veeeeery convenient to cool down the car so again many thanks.
So far I understand the process , i feel a bit lost on the asbuilt data part , dont expect you to detail it more( its welcome anyways ... :P) but if you can link any topic where I can find it would be super as I dont want to mess with anything.
Regards from Spain and if it happens that you com close to Alicante area youre welcome to eat a nice paella ;)
Re: REMOTE START
look it's
but I didn't change anything from this RTM module
2 original keys and one remote start key are working very good ;)
https://www.youtube.com/watch?v=k76ESOMS5z0
astrap16v
Vehicle: Mondeo Tdci 2.0 2015
Re: REMOTE START
Post by astrap16v »
This is only valid for models with automatic change, right?
Re: REMOTE START
astrap16v wrote: Sun May 03, 2020 6:55 am This is only valid for models with automatic change, right?
yes :!:
ReNeGaDo
Re: REMOTE START
Post by ReNeGaDo »
fordsmax471 wrote: Sat May 02, 2020 5:11 pm look it's
Thanks will see if i can manage to make it once I get the key. One more question, my fob has 2 parts , the detachable key and the remote , where is the transponder located?? My key lookd like this one https://sc01.alicdn.com/kf/H12bd10b3e43 ... .jpg_.webp ( i know this is not the correct one)
Re: REMOTE START
it is a safe procedure, mark the keys 1, 2 and 3 and program
andyh1108
Vehicle: Edge 2.0 TDCi 210
Re: REMOTE START
Post by andyh1108 »
Programming keys
Thanks for the information, I assume this is a UK vehicle as I want to add this to my Edge. Can you tell me where you got the key from?
Andy
