OBDLink® EX
f-wolf
Vehicle: *** Ford ***
OBDLink® EX
Post by f-wolf »
ForScan
December 10, 2019 - OBDLink EX adapter is available
OBD Solutions company has released their brand new OBDLink EX USB adapter. This product was created specially for our project, FORScan team was directly involved in testing and refinement of the adapter. In addition to high performance and MS-CAN bus support, OBDLink EX has a set of advanced features that make it comparable to expensive J2534 PassThru devices but for a very reasonable price.
Just got one ... https://www.obdlink.com/ex/
Works well ...
Got the new driver from here: https://www.ftdichip.com/Drivers/VCP.htm
youabd2002
Vehicle: Expedition, Triton 5.4/ 2013
Re: OBDLink® EX
Post by youabd2002 »
Is it compatible with UBP bus?
f-wolf
Re: OBDLink® EX
Post by f-wolf »
That I don't know ... !
PS ... Have a read here:
Post by FORScan » Fri Mar 30, 2018 7:52 pm
Update 2019-12-11. Article updated as the following:
- Added reference to OBDLink EX
viewtopic.php?t=6142
And if you can't find an answer ...
Try here: memberlist.php?mode=contactadmin
Airborne_Ape
Vehicle: F150 Hybrid 2021
Re: OBDLink® EX
Post by Airborne_Ape »
youabd2002 wrote: Fri Dec 27, 2019 7:53 pm Is it compatible with UBP bus?
No.
Airborne_Ape
Re: OBDLink® EX
f-wolf wrote: Fri Dec 27, 2019 5:27 am
I would like to know where this information is coming from because the actual stats posted by the ForScan admins indicate the OBD Link EX is only capable of 25% of the throughput compared to a real ELS27 v3. What makes the OBD Link EX special? does it have something to do with the STN2230 chip?
I don't understand how it's comparable to a J2534-2 device; just seems like false advertising to me.
FastFreddi
Vehicle: Expedition Max 2019
Re: OBDLink® EX
Post by FastFreddi »
I think it will be a great replacement for ELS adapters once firmware issues are solved as the STN chip is newer than ELS27.
Here is info from FORScan Support:
"Also it was found out that there are problems with firmware update on some slow modules using OBDLink EX + new STN command set, so we had to temporarily disable new STN API until ScanTool fixes it and releases new firmware. Without the API firmware update works much slower on EX than on UCDS. We (FORScan team and ScanTool team) are hopeful to resolve all these issues in 1 month. Sorry for the inconvenience."
"- It is not recommended to use china ELM327, as it is impossible to guarantee stable work in there. ELM327 Adapters that proved their ability to program firmware:
-- OBDLink EX
-- Ford VCMII original
-- VXDiag VCX Nano for Ford/Mazda
-- ELS27 - original (clone may hang after 30-40 minutes of work)
-- OBDLink SX (doesn't support MS-CAN, so may need to be modified for it)
-- VINT-TT55502 USB (marked as Ford/Mazda/FORScan compatible, with HS/MS CAN switch). Update: one user was unable to program SYNC3 with it.
-- VeePeak USB (marked as Ford/Mazda/FORScan compatible, with HS/MS CAN switch). Update: one user was unable to program SYNC3 with it."
Airborne_Ape
Re: OBDLink® EX
I ran a preliminary test and posted my results here:
https://www.f150forum.com/f118/forscan- ... ost6458386
The OBD Link EX is about 15 times slower than my ELS27, but I realize it's still a work in progress.
I'll try it again when the new drivers are out and it has more time to mature. For now, I will recommend the OBD Link EX, but only to people who want a 'cheap' adapter without the HS / MS switch.
Re: OBDLink® EX
you are fine with this FTDI driver setting :?:
latency timer.JPG (42.71 KiB) Viewed 30204 times
mitch123
Vehicle: 2014bf150 ecoboost
Re: OBDLink® EX
Post by mitch123 »
I have both the one with the switch and I just bought the new one yesterday thinking it is better,which should I continue using
Re: OBDLink® EX
which adapter :?:
