American 6.0L V8 Diesel cylinder balance/injector test
ScottKrieger
Vehicle: 2003 Ford Excursion 6.0 Powerstroke Diesel engine
Re: American 6.0L V8 Diesel cylinder balance/injector test
Post by ScottKrieger »
Well, those tests are not in there so the online documentation is wrong.
Forscan did help me diagnose my #8 injector as bad, but the CCT test would definitely be a big help on these engines.
jmontgomery453
Vehicle: F250, 6.0 Powerstroke, 4x4, 2006
Post by jmontgomery453 »
How were you able to determine what injector was bad? My injectors pass the “click test” but I obviously have one or more that are not firing until the engine is at running temp. Even then I am getting skips. I have watched the ficm and the voltage is good.
scooters6.0
Vehicle: 2006 F350, 6.0 Powerstroke
Post by scooters6.0 »
So I have a 2006 F350 6.0 and have noticed smoking when cold, no hard starts but rough idle etc.
I got forscan set up and did a buzz test the other day and everything past, all the clicks were there.
I tried again this morning when everything was cold and I believe 4 and 8 did not click.
Ran the truck to check for misfires and everything was good.
Then it past the click test after running (roughly) for about 5 min.
My question is does the injector shut down work on the 6.0 powerstroke?
Nutloose
Vehicle: BMW E36 V6 Project
Post by Nutloose »
let the engine go cold and retry the test.
If the same cylinders fail to click... warm the injectors with a hot air gun or boiling water and try it again
It might prove the fault is temperature related.
try injector cleaner additive
Ralberta
Vehicle: 2006 F350 6.0 Diesel
Post by Ralberta »
Has there been any update on this? I am looking into my options for what kind of setup i need to run reliable contribution tests on 6.0 diesels. Any help would be appreciated. The OTC Encore handheld unit looks awesome but it's over $2,000 Cad, so I'm looking at the forscan route. Apparently autoenginuity doesn't preform a reliable contribution test from what I've heard.
Papa_G
Vehicle: F250, 6.0 Diesel, 400hp, 2003
Post by Papa_G »
Ralberta wrote: Fri Sep 20, 2019 2:21 am Has there been any update on this? I am looking into my options for what kind of setup i need to run reliable contribution tests on 6.0 diesels. Any help would be appreciated. The OTC Encore handheld unit looks awesome but it's over $2,000 Cad, so I'm looking at the forscan route. Apparently autoenginuity doesn't preform a reliable contribution test from what I've heard.
Just curious as I have AE and ForScan. Do you have more detailed info on the reliability issue reported with the AE cylinder contribution testing?
DieselTechnician
Vehicle: 2006 F250 RIG
Post by DieselTechnician »
AutoEnginuity's "contribution" / "power balance" test is fundamentally useless and very misleading.
Capt_Tom
Vehicle: F250,Diesel,6.0,2006
Post by Capt_Tom »
So far as I can see only the IDS has the ability to do a cylinder power balance test without the computer compensation hiding the problems. I have auto enginuity and it is pretty useless for this. I have been to three shops that have Snap On, OTC, etc... same issue. They can’t see past the computer compensation, I was hoping that Forscan could help. Refreshing but not there
Jake012
Vehicle: 1999 f250. 2012 f350. 2009 MGM
Post by Jake012 »
Capt_Tom wrote: Sat May 09, 2020 12:56 pm So far as I can see only the IDS has the ability to do a cylinder power balance test without the computer compensation hiding the problems. I have auto enginuity and it is pretty useless for this. I have been to three shops that have Snap On, OTC, etc... same issue. They can’t see past the computer compensation, I was hoping that Forscan could help. Refreshing but not there
My dad has ford ids and now the new fdrs i believe they call it and i gotta say WOW. i can see why their diagnostic systems are so expensive and its nice to do tests on the trucks while im inside on the laptop when its -35 out. I showed him forscan and he was actually very impressed with it we went through his 12 f350 6.2 and he was impressed with how much it showed and everything and i am too, download was free extended licences is 50 bucks for lifetime which is way cheaper then ids and i can watch and test stuff in real life it doesn't get much better then this without spending a arm and a leg. give it some and im sure they'll come up with something soon he's actually going to download it too since you can change stuff on these trucks while ids cant.
DWLEMAL
Vehicle: Ford 2004 F350 6.0 diesel 350hp
Post by DWLEMAL »
it is there
