2.4.1 - APIM Firmware update doesn't work
Re: 2.4.1 - APIM Firmware update doesn't work
Use 2.4.2 Please, and make sure to toggle FORCE PROGRAM, after that tell us what happenskurek99 wrote: Fri Sep 18, 2020 9:25 pmFailed to. Same error. Used Forscan 2.4.0 20200309AHNA1711 wrote: Fri Sep 18, 2020 7:24 pmUse Forscan v2.4.0 to update the APIM calibration. Select custom firmware and upload the original files of your APIM then click update.kurek99 wrote: Fri Sep 18, 2020 7:12 pm I have a saved APIM configuration before the upgrade. Saved configuration before programming.
If it still didn't work try the following:
- Delete vehicle profile, and make new one
- Load ab files and reset module
- Clear DTC codes
- Re-try programming
- Make sure you have a decent adapter e,g, OBDLink with latest SCANTool firmware 5.5.3
If all failed contact support they're very helpful!!
Got sent a link today to 2.4.3 test so loaded on laptop and had a go on the car. Followed the procedure and it seemed to flash ok 5 different parts. Said procedure completed successfully. Did a reset then went into asbuild and changed 7DO-02-03 from 0000 to 0600 gave me a checksum error but wrote anyway. Went into radio settings and option to switch on radio logos had appeared. Switched it on and checked logos in Dab and they were there and working. But as soon as i went off DAB they disappeared and cant get them back. Has APIM got right files in it do I need to try and see if there are more updates available ?
- WhatsApp Image 2020-09-19 at 21.08.13.jpeg (70.14 KiB) Viewed 5740 times
AHNA1711
- Vehicle: 2017 Ford Explorer Limited 4dr SUV AWD (3.5L 6cyl)
HelloHalda wrote: Sat Sep 19, 2020 8:22 pm Got sent a link today to 2.4.3 test so loaded on laptop and had a go on the car. Followed the procedure and it seemed to flash ok 5 different parts. Said procedure completed successfully. Did a reset then went into asbuild and changed 7DO-02-03 from 0000 to 0600 gave me a checksum error but wrote anyway. Went into radio settings and option to switch on radio logos had appeared. Switched it on and checked logos in Dab and they were there and working. But as soon as i went off DAB they disappeared and cant get them back. Has APIM got right files in it do I need to try and see if there are more updates available ?
Wow, just figured out how to get 2.4.3. I'll see if it works tomorrow after eye surgery. Don't know when I'll be back on.Halda wrote: Sat Sep 19, 2020 8:22 pm Got sent a link today to 2.4.3 test so loaded on laptop and had a go on the car. Followed the procedure and it seemed to flash ok 5 different parts. Said procedure completed successfully. Did a reset then went into asbuild and changed 7DO-02-03 from 0000 to 0600 gave me a checksum error but wrote anyway. Went into radio settings and option to switch on radio logos had appeared. Switched it on and checked logos in Dab and they were there and working. But as soon as i went off DAB they disappeared and cant get them back. Has APIM got right files in it do I need to try and see if there are more updates available ?
Success finally ! Had to update 3.4 ver 20021 to 3.4 ver 20196
finally updated my AIPM software. Used 2.4.3 but still no calm screen options. Oh well, not worth bricking.
AHNA1711
You can activate Calm Screen from APIM Module Configuration search for Calm Screen and select Enable then Write.esqueue wrote: Tue Sep 22, 2020 12:47 am finally updated my AIPM software. Used 2.4.3 but still no calm screen options. Oh well, not worth bricking.
I activated via the asbuilt codes. When I checked this method, it already is set to enabled.AHNA1711 wrote: Tue Sep 22, 2020 6:54 amYou can activate Calm Screen from APIM Module Configuration search for Calm Screen and select Enable then Write.esqueue wrote: Tue Sep 22, 2020 12:47 am finally updated my AIPM software. Used 2.4.3 but still no calm screen options. Oh well, not worth bricking.
- ttlandcmos
- Vehicle: Ford Fusion 2017 Sport 2.7L
How can i get url for forscan v2.4.3?esqueue wrote: Tue Sep 22, 2020 12:47 am finally updated my AIPM software. Used 2.4.3 but still no calm screen options. Oh well, not worth bricking.
