2.4.1 - APIM Firmware update doesn't work
kurek99
Vehicle: Fusion 2017 1.5 182
Re: 2.4.1 - APIM Firmware update doesn't work
Post by kurek99 »
2B-4G10
Vehicle: F150, Gas, 5.0, 420+HP, 2018
Post by 2B-4G10 »
kurek99 wrote: Fri Sep 18, 2020 9:25 pm
AHNA1711 wrote: Fri Sep 18, 2020 7:24 pm
kurek99 wrote: Fri Sep 18, 2020 7:12 pm I have a saved APIM configuration before the upgrade. Saved configuration before programming.
Use Forscan v2.4.0 to update the APIM calibration. Select custom firmware and upload the original files of your APIM then click update.
Failed to. Same error. Used Forscan 2.4.0 20200309
Use 2.4.2 Please, and make sure to toggle FORCE PROGRAM, after that tell us what happens
If it still didn't work try the following:
- Delete vehicle profile, and make new one
- Load ab files and reset module
- Clear DTC codes
- Re-try programming
- Make sure you have a decent adapter e,g, OBDLink with latest SCANTool firmware 5.5.3
If all failed contact support they're very helpful!!
Halda
Vehicle: Mondeo Vignale 2016 2.0l diesel estate nav
Post by Halda »
Got sent a link today to 2.4.3 test so loaded on laptop and had a go on the car. Followed the procedure and it seemed to flash ok 5 different parts. Said procedure completed successfully. Did a reset then went into asbuild and changed 7DO-02-03 from 0000 to 0600 gave me a checksum error but wrote anyway. Went into radio settings and option to switch on radio logos had appeared. Switched it on and checked logos in Dab and they were there and working. But as soon as i went off DAB they disappeared and cant get them back. Has APIM got right files in it do I need to try and see if there are more updates available ?
WhatsApp Image 2020-09-19 at 21.08.13.jpeg (70.14 KiB) Viewed 5745 times
AHNA1711
Vehicle: 2017 Ford Explorer Limited 4dr SUV AWD (3.5L 6cyl)
Post by AHNA1711 »
Halda wrote: Sat Sep 19, 2020 8:22 pm Got sent a link today to 2.4.3 test so loaded on laptop and had a go on the car. Followed the procedure and it seemed to flash ok 5 different parts. Said procedure completed successfully. Did a reset then went into asbuild and changed 7DO-02-03 from 0000 to 0600 gave me a checksum error but wrote anyway. Went into radio settings and option to switch on radio logos had appeared. Switched it on and checked logos in Dab and they were there and working. But as soon as i went off DAB they disappeared and cant get them back. Has APIM got right files in it do I need to try and see if there are more updates available ?
Hello 👋, How to get the new test version 2.4.3 please?
esqueue
Vehicle: Lincoln MKZ 3.0t AWD 2017
Post by esqueue »
Wow, just figured out how to get 2.4.3. I'll see if it works tomorrow after eye surgery. Don't know when I'll be back on.
Halda
Post by Halda »
WhatsApp Image 2020-09-20 at 23.59.24.jpeg (164.44 KiB) Viewed 5602 times
The attachment WhatsApp Image 2020-09-20 at 23.59.24.jpeg is no longer available
Success finally ! Had to update 3.4 ver 20021 to 3.4 ver 20196
esqueue
Post by esqueue »
finally updated my AIPM software. Used 2.4.3 but still no calm screen options. Oh well, not worth bricking.
Screenshot 2020-09-21 174239.png (305.88 KiB) Viewed 5582 times
AHNA1711
Post by AHNA1711 »
esqueue wrote: Tue Sep 22, 2020 12:47 am finally updated my AIPM software. Used 2.4.3 but still no calm screen options. Oh well, not worth bricking.
You can activate Calm Screen from APIM Module Configuration search for Calm Screen and select Enable then Write.
esqueue
Post by esqueue »
AHNA1711 wrote: Tue Sep 22, 2020 6:54 am
I activated via the asbuilt codes. When I checked this method, it already is set to enabled.
ttlandcmos
Vehicle: Ford Fusion 2017 Sport 2.7L
Post by ttlandcmos »
How can i get url for forscan v2.4.3? :cry:
