Hi Folks,
I have a dead IPMA Modue on my Ford Focus MK3 2011
With UCDS there you can force a reflash.
Can I do with Forscan the same? How can I reflash a dead Module?
Thanks for Help
Best regards
Karsten
ReFlash dead Module with Forscan 2.40???
- LaForge
- Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
- Contact:
Changed on my 2011 Focus:
Re: ReFlash dead Module with Forscan 2.40???
i have force programming option
- LaForge
- Contact:
Hmm I’ll give it a try
Regards
Karsten
Regards
Karsten
- ddg71
- Vehicle: Ford Mondeo 2.0 TDCI Powershift, 180 HP, mk5, 2016
hello, work dead mode forcing option ?
Forscan 2.4.2 , Obdlink EX
- ddg71
I broke I think with a clone of UCDS PRO + IPMA module ... when writing the block FT4T-14G081-HE I got the message Failed ...... I then tried with the original Obdlink EX interface to rewrite it in Forscan but it does the same ... it stops writing the last block ... how could I rewrite it ? please help !
- IMG_2288.jpg (438.33 KiB) Viewed 5541 times
- IMG_2289.jpg (284.16 KiB) Viewed 5541 times
- fordsmax471
try this option
"Stop activity on buses "
- ddg71
and "Force program unchanged firmware" ?
- fordsmax471
yes
- fordsmax471
if this still does not work, install the files separately
1.
...21..
...19..
...82..
do not turn the ignition off
2.
...21..
...24..
3.
...21..
...81..
1.
...21..
...19..
...82..
2.
...21..
...24..
3.
...21..
...81..
Be careful when flashing IPMA's. Some people get the file order wrong. Might want to double check it.
